Fenrir Enterprises
- May 17, 2006
I've been using an Epson R220 for quite awhile now with pigment refills - I print artwork with it, as well as signs to laminate for outdoor use - quite happy to be able to make signs that don't fade in a few days (though the lamination usually fails in about a year and a half of direct sunlight, I need to find UV resistant pouches). However, I've grown tired of fighting with the printer - it never feeds properly with any stock thicker than 24 lb paper, and I have terrible banding issues whenever I refill it - the only solution seems to be to wait a day or two before it'll "settle down" - which requires me to plan ahead and refill it several days before a large print run. I know the printer isn't meant for huge print runs - but if I print a lot all at once it eventually starts banding again unless I set it on photo mode, which makes it slow as molasses. I'd known about some of these issues when I started using refills - the benefits of pigment ink was worth it (and yes, I've tried several types of refill carts).
It's finally gone too far out of alignment for certain jobs - I can't print two-sided business or post cards anymore because they don't line up when I cut them out. I have a spare R220 in storage (and an R340 that's always been used with OEM inks that I use for glossy photos) but I'm wondering if any of their newer six-color printers under $250 work decently with pigment inks and have less problems than the R220 does. I had started with a C88+ but I found that 4-color pigment printing was too dark - I couldn't get any blue brighter than "dark navy" out of it. I keep seeing comments like "it sort of works" and "require customized profile", but I've never had a problem with the color differences on the R220 - it was pretty easy to work with. Also does the higher printhead resolution result in more clogs?
Or should I just get the backup printer out of storage and start cutting it up for the waste tank modification?
