chirantha7777
- Oct 5, 2009
My very first refill was with a Canon BJC 1000SP. The cartridges were very expensive and I didn't know about refilling. I was around 14. I was sick of ink running out so what I did was took out the BC-6 cart and punched three holes at the top using a heated screw driver. Used screw driver to poke and see the colors and fill the cart with plane tap water. I printed a lot this way. I used insulation tape to seal it off.
Canon has always given me problems... Their print head even in the BC-06 sometimes died before the original ink was finished. Taking the price back then ($USD 60 for BC-06, USD 40 for BC-05) Canon was a real pain.
Then peaces started falling of the BJC 1000SP so I bought
1. IP3500 - died from using wrong ink
2. IP1980 - print head never lasted through the second refill
3. IP3680 - Hopefully running. but seeing starvation issues after like 4 refills
Now I moved to Epson.... even if there is a ink clog I won't burn the print head.
