crenedecotret
 - Oct 5, 2006
Hi everyone,
I made a custom ICC profile for another member here. Before we started he mentioned that the black ink cartridge might be giving black levels that are way "too black" compared to the OEM ink. Nozzle checks were all good, and there are no feed issues/leaks. His printer settings were all good. Printer color management turned off, etc. He is using Canon paper so that's one less variable to worry about. The only thing that is not OEM is the ink itself.
He printed the color patches, sent them to me... I created the profile with what seems to be good results using Argyll and a Colormunki. Very very low avg DELTA-E errors, almost the best i've seen (avg. = 0.328429, RMS = 0.452294). I evaluated the profile the best I could, soft proofing in both Gimp and Photoshop. I use a calibrated monitor so the soft proofing is somewhat valid. On profiles i've done for myself, the soft proof on the screen matches the actual print. With this MG6220 profile I made, soft proofing shows shadow details that I am unable to achieve with my current setup (IP4500 and hobbicolor inks). This leads me to believe that the black and grey inks are absolutely fine.
Now when he tried the profile, he seems to still be having the same "black is too black" issue. He is seeing this on the "PDI test image" that is circulated on the web. I suggested he compare an un profiled print and a profiled print outside in daylight. He did mention the profile print looked better, with more saturated colors, etc.
Since he is not entirely happy with the results. I thought I might consult all of you here....... I suggested the prints dry for a day or two and look at them in daylight around noon to be able to accurately judge the colors and appearance. (at home, I use an ott lite). I also suggested that since his monitor is not calibrated, the colors/appearance he sees on the print might be the more accurate one. Another suggestion was to drop the PDI test image and use normal photographic material more likely to contains colors that the printer will actually be able to reproduce.
I believe this member was hoping that an ICC profile would correct what he perceives is an issue with his black ink. Some combinations of paper, printer and ink are simply hopeless even with a profile, but I don't think this should not have been the case with Canon paper and IS ink that is known to be very close to Canon's.....
Is there any chance that the black ink he was provided might not be the right one for his printer? Mikling? I'd love to hear your opinion on this, have you had any issues with MG6220?
To everyone else... Would anyone with the same printer and inkset like to try the profile? I can distribute it freely since it was done with Argyll.
