Mg 5150
pyrogeorge
Hi,
I would like to refill my canon MG 5150 cartridges and i need your help..How can i refill it?
Any guide or tips i will appreciate it,
thanks!
pyrogeorge said:
Hi,
thanks!
As these 526 cartridges are opaque there not the easiest cartridges to fill so you can use a work around.
Get yourself a set of 520/521 and swap the chip from the 526s to them then you can fill these cartridges with ease. :)
The Hat is too modest to toot his own horn and post his link on chip swapping. Here it is.
pyrogeorge
Hat,
Do you refer to MG520/521 or MP?Also i found and pgi 520..wich cartridge dou you refer?
thanks for your replies!
pyrogeorge said:
Hat,
Your printer uses 525/526s so replace them with 521/520s or 221/220s
it doesnt matter whether their called MG or MP cartridges there are all the same size,
yours are fully opaque and the others are not..
pyrogeorge
I can't refill it more times than once?
I have also and hp printer and i refill it more than 10 times!!!!(the black)
I will repeat myself it again dont get compatible cartridges for continued refilling.
Canon cartridges are by far a better choice and are better that any other cartridge out there.
Refilling compatible cartridges will give you more trouble than their worth,
stick with OEMs and a resetter and you will have trouble free printing for a long long time.
Buy cheap and youll get nothing but rubbish and that goes double for inks.. :th
