L800 colour pattern
Borut
Slovenia
Canon Pro 10s
Can someone tell me can be this resolved?
Prints are for no use.
I did replace inks,and i did use windexs pads under print head,no change.
How does the regular nozzle check look like ? Which ink did you use for refill ?
Borut
Slovenia
Canon Pro 10s
original inks epson
nozzle check is miss color bay cyan and magenta
Borut
Slovenia
Canon Pro 10s
Oh...... before changing inks same problem,,
so i did think that inks are the problem but not.
you can download the WicReset utility and use the Ink charge button , I have the impression that the ink was running low already before you refilled the ink. There are cartridges in the printhead carriage , they keep a small amount of ink which run low if the inks in the tanks get too low. This inhibits further ink flow even if you refill again. Do you have the valve switch at the ink reservoirs in the open position ?
Borut
Slovenia
Canon Pro 10s
sure it is open :)
ink flow is ok in cartriges
i dont now why is in magenta nozzles cyan ink
Hate to say this but it looks like your L800 printhead may be failing between the Cyan and Magenta channels. Saw the same thing in the L800 we used for testing. I've not checked to see how the head is designed but my guess is that there's a grommet or gasket that's in there and that's not sealing properly, allowing a small amount of cross contamination.
Keep trying other options to see if the situation resolves itself but if not, it's worth looking for replacement printheads from aliexpress and doing a swap out with a new head.
Borut
Slovenia
Canon Pro 10s
I did take out the head and it look that nozzles are clean,so the head is fail like you say cross contamination.
so printer dead after 2years.
So now which printer to buy ?Maybe L1800?:)
I don't whana buy a printer again for only 2 years.
