avolanche
My MP780 had a clogged head(QY6-0049)-same head as ip4000 and i860.I repeatedly used Windex and alcohol in all the ways recommended on this forum.The Magenta continued to be clogged after days of soaking,flushing,etc.I could get fluid through the M nozzles with a 20cc syringe,but it took much more pressure than the C,Bk,Y nozzles.I finally took it apart(the ceramic part) which I think is of no use to do.While I had the ceramic part loose,it fell off-basically making the cartridge useless(It's held on with glue and had gold contacts-impossible to reassemble).
So I decided to try one more thing.I removed the "screen" where the ink initially enters the head(at the cartridge outlet).That's where the pressure was backed up.I found no signs of anything that was causing the blockage there-no ink or particles-nothing.But the ink certainly flowed freely again.I don't know if that screen is supposed to add any "back-pressure"-I would think not.If you have an impossible clog,it may be worth removing the screen over the offending color.I doubt if it can be replaced,but as a last resort,why not?
