Is there a LC-51 flush cartridge? etc.
BOYNTONSTU
Thinking about a syringe and cleaning solution method to flush a clogged print head. (Magenta!!!)
If one could buy a cartridge filled with cleaner it would be a perfect fit for the fill channel.
Perhaps just using the clean cycle would be sufficient.
If not, pressurizing would be the next step.
A refillable transparent cartridge would be ideal because it has a fill hole that you could pressurize with a syringe.
What about an empty regular cartridge?
Instead of filling it with ink, use Windex or some other magic juice.
I would drill the refill hole at the rear of the cartridge near the top for easy access for a syringe.
Has this been done?
