Q) Error 03800500-2F42 appears on my printer
A) The error ending in 2f42 & 2f43 relates to a certain number of nozzle that are block in your print head. Run a nozzle check pattern to see which print head needs replacing."
http://www.ipfprinter.repair/Canon-iPF750-Printer-Repair.html
1) Did you buy the printer new or was it used?
2) Has there always been a problem or did the printer once work perfectly for you?
3) What was the issue that caused you to buy a new print head? Did it come and go, happen suddenly, get worse over time, ever improve, etc? What have you done to correct the issue? Please be as detailed as you can.
4) Where did you buy your new print head from?
5) Anything change since installing the new print head or is the issue the same as before?
6) Have you tried the instructions in your manual concerning head cleanings?
See pages 740 of the manual. Do no more than it instructs as repeated deeper head cleanings may lead to nozzle burn out.
https://gdlp01.c-wss.com/gds/1/0300004471/02/iPF750-UserManual-Eletter-140.pdf
If you can, please scan the nozzle check, crop and save to an image file and then post. While we can clearly see the lack of certain nozzle colors, the other nozzle check latticework of lines is distorted and I cannot tell if there are issues with them.
