dirtyfingers
Print Lurker
- Feb 25, 2017
- Canon ip90
(1) Hi all. My trusty ip90 has lost its mind. It will not longer put ink to paper. It goes through all of the proper motions but nothing comes out.
(2) It started about one month ago with the black ink not printing but color was fine. I cleaned the print head. Black still didn't work but color did. I used it for probably 30 pages in color. Then, the color side stopped printing too. Both had ink on their nozzles. I took the print head out and cleaned it again. I let it soak and flushed it until the nozzles ran nearly clear. Let it dry. Put it back in the printer and got a bad print head notice.
I bought and installed a new print head along with new OEM inks. I still wouldn't print. I pulled the top cover to check out the purger. It seems to be functioning. I cleaned the ink collector pad and after two reboots, it was saturated. The gears for it are functioning as is the little swiper. I am at a loss. What else can I check?
(3) Canon ip90 - Since 2009 - a couple of times a month to print about 5 sheets or so.
(4) & (5) I started with OEM inks but, being in the desert, the print head would dry out between uses and then I would have to run three deep cleanings which would take the remaining ink out of the cartridge. It was costing $5 to print a handful of papers. I started refilling my own about two years ago.
