- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
Normally an electronic print head failure will show in the nozzle check as pigment ink ink pattern totally missing or missing the upper or lower half or show a picket fence pattern. If the failure is in the dye ink section, the dye inks may be missing completely or one or more bands may show an upper or lower half that is considerably lighter than the other half. Here is a nozzle check from a Pixma 3600 that at first glance appears to show only clogged magenta nozzles:
But at a closer look you see some vertical lines in the normal magenta band. A test print from service mode reveals what I think is an electronic print head failure, and then no amount of cleaning will save this print head:
I think a nozzle check like this, in case of an electronic print head failure, has not been posted before. At least I had not seen it before.
