- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Having hit something of a problem with sourcing appropriate bottles that fit the SquEasyFill caps I'm trying to work out the best approach to providing inks in volumes that people want but in a way that makes sense.
To date I've had access to:
50ml
60ml
100ml
125ml
250ml
...bottles but due to problems with manufacturers going bust, lines being re-tooled, etc... I'm now losing access to suitable bottles for 60ml, 100ml and 250ml volumes.
The key limitation in all of this is the neck size required by the caps. This is quite small and limits the options, especially for larger volumes.
I could regain a stock of the 60ml bottles if I were to import but the cost implications are quite dire, and frankly the benefit of a smaller volume is lost if the bottle cost means it'd be cheaper to put 60ml in a 125ml bottle instead.
As to the 250ml or higher, the only option has been a tall, small diameter base which makes them prone to falling over, so that's not ideal either.
Another key factor with larger bottles is that a 250ml bottle is actually quite heavy and less comfortable to hold, so I find myself wondering if perhaps it would be better to switch larger volumes to non-SquEasyFill type but with a fixed spout cap that would allow them to easily refill the smaller 125ml bottles. This would make the 125ml bottles the default SquEasyFill kit and adds an element of extra waste but seems to resolve the technical limitations in a simpler, more sensible way.
The alternative is to go with bottles that have a wider neck size and go the manufacturing/customisation route by converting caps to integrate the luer fitting (much like I've done with Canon flush clips). This would however have cost implications both cash and time wise, as the caps would have be built by hand.
So, with all this in mind I'm asking for your input on the following:
1. Would you consider a 50ml volume a good volume for a starter refill kit, even for say the pigment black (if applicable)?
2. For larger volumes (250ml+), would you view the weight and extra cost issues, of making them SquEasyFill compatible, less attractive if the bottles could be decanted into SquEasyFill 125ml bottles easily?
Right... the next question is about volume availability...
For Canon printers I'm making inks available as follows:
Starter bundles
50ml Dye inks
60ml Pigment Black (will be switching to 50ml once stock runs out for 60ml bottles)
Standard bundles
100ml Dye inks
125ml Pigment black
In your opinion, would it be worth switching to:
Starter: Include 125ml Pigment black with the other 50ml bottles rather than dropping the pigment black to 50ml too?
Standard: Up the volumes in dye inks to make them all 125ml (pigment and dye)?
I'm just aware that the jump might be a bit too much for some users but I'd be interested in your thoughts and rational before I make any decisions...
Thanks in advance for your thoughts...
50ml
60ml
100ml
125ml
250ml
Starter bundles
50ml Dye inks
Standard bundles
100ml Dye inks
125ml Pigment black
