Ink starvation.
Tigerman
Jordan
Canon MG5640, iX6840
Hi,
After I done three level of print head cleaning for 932 black I got these results.
and also cartridge check
this is first time happen to me after long time I use refillable black cartridge, the color also refilled but no problem.
Hi Issa
This problem you have is indeed ink starvation so I reckon you could have an air leak somewhere in your system !
The cartridge may not be seated properly in the printer or there is a leak inside your cartridge that is of course that there was no air left inside the cartridge after you have finished refilling it, another problem could be that the cartridge outlet may have got damaged in the filling process..
Tigerman
Jordan
But this first time to happen with me after so many refill I use refillable black cartridge, I done 9000 mono black super B papers !!? why now this problem start with me ? I use OEM but no problem with black may be need flush print head ??? HOW ?
After do three level scan after 20 pages problem come back again, sometime with refillable OEM late till or may be never starvation.
When use printer after long period idle or no use (1 day) then ink starvation be clear. :oops:
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Yes, that appears to be ink starvation. There is probably a flow blockage to the print head. Did you try a different cart?
Tigerman
Jordan
Yes, OEM work perfectly !
