INK CARTRIDGE ERROR REPLACE CARTRIDGE on Epson 9700
Milton Mariano Castaño
Epson 1410
IF YOU DONT KNOW HOW TO FIX THIS ERROR PLEASE DONT FILL WITH GENERIC USELESS ANSWERS.
hi every one. My epson 9700 start to show this error after i clean manually the head printer. i think that the problem is in the mainboard but not sure. I Will change the headprint with a new one but first i want to fix the error. any suggestion? please dont adviseme to change the cartridge, reset cartrige, clean contacts, do a specific secuential of cartidge intalation, chek the air in the hoses or change drivers or pc, because i did all that. If the problem is in the mainboard could i fix it? i had the same problem in the epson 1410 and i fix it by making a by pass in the F2 fuse in mainboard...i think that probably the same solution will work in the epson 9700 but i not sure. What do you think? thanks very much.
L310/382/1800, P400, Pro7600
It's not clear to me what you have done so far - how did you clean the printhead - did you take it out ? What are the problems ? I assume that you do refill with your cartridges - into the original Epson ones - or 3rd party cartridges ?
Is the chip still in place, not loose , not turned or shifted away by the frequent insertion cycles ? Do you have a backup cartridge, another one you can use for a test that that one is working ? Can you inspect the contact pins in the cartridge housing - you would need a LED lamp and some kind of dentist's mirror to get there - it could be that one of the contact pins is bent or broken - so testing that with an alternate cartridge would help.
I would not think at this time that this is a problem with a blown fuse , and it is unclear whether the electronics of this printer are similar to your 1410 in this respect. You can search for a service manual, but I'm not sure that it would give you a circuit diagram.
Moderator
Wicklow Ireland
Canon were, BUT 3D are better.
No I won’t ask you to change anything, but I will ask a question:- are all these carts OEM and how much ink is left inside them.. my money is on the carts… Low ink ?
