i9900 Printing Problems
Collin.O
While printing pictures, the photo seems to come out with pink streaks across the page.
I replaced the Heads and changed out the ink, and did a cleaning, the tester came out with no issues, however when i went to print again, i still got the same pink lines on the photo.
Thoughts?
Thanks.
Tin Ho
Try to post a scan of your photo that has the streaks on it. This helps to see what the problem may be. Look at your nozzle test print carefully. It should give you some information about the problem too. If both your print heads do the same thing you should put the new one into storage immediately. You will need to figure out a way to prevent ink in the nozzles from drying out and plugs up. Once the ink in the nozzles dry out it will be very tough to clear the clog.
