My i560 prints magenta (with yellow) when I print a yellow test page. If I print with only the yellow cart installed, the print is perfect with not a trace of contamination. As soon as I re-install the other carts, the magenta overpowers all other colors with lots of banding. I rinsed the print head in hot water but no improvement. I've searched here for a solution to no avail. I'm using Costco refill ink and mixed the photo inks with the others to stretch it, but that should only cause washed out colors, I think. The printer sits for weeks without use, but if it were a clog issue then yellow would not print perfectly as it does when it is the only cart in the unit. Can anyone help me with a solution other than buying another printer? Thanks.
p.s. I just now removed the yellow cartridge and there is magenta ink inside of it. How is the magenta getting in there? I had just flushed out the entire cart since I thought I had drunkenly put magenta into it previously but now I see that it is somehow sucking up the adjacent color.
