I am unable to turn on my Canon PRIXMA MX870 printer. Please help!
joseph1949
Albany, Oregon, USA
I unplugged my printer to do a refill. Before I did the refill I decided to do one more print. I plugged the cord back into the wall. I see the following message on the LCD:
C000
Printer error has occurred.
Turn off power then back on again.
If problem persists, see the manual.
I have turned the power off and then back on again. I still get the C000 message.
I cannot call Canon until Monday. Canon is closed on the weekends!!!
I will go to the Canon site to see if there is a FAQ that can help me.
I have checked the manual and I cannot find a solution. I will do more Search to see if I can find an answer.
Question: Can someone please help me with this problem?
Thank you.
joseph1949
Albany, Oregon, USA
To: stratman
Thank you for your reply.
Before I received your reply I googled C000 and various forms of Canon PIXMA MX870 printer will not turn on. I did not get much back that was helpful.
I googled your phrase and saw the follow site:
http://www.wiki-errors.com/wiki-errors.php?wiki=c000
This site says I have a registry problem!!! How can my pulling the plug from the wall cause a registry problem??????
I may have to wait until Monday to call Canon to fix the problem.
Any ideas?????
Thank you.
joseph1949
Albany, Oregon, USA
To: stratman
It seems that the yellow cart is problematic. It does not have a solid click when you seat it in. I replaced it with a newer yellow cart and the C000 message disappeared and the printer behaved correctly. I then replaced the newer cart with the problematic cart and no error messagestrange!!! I will use the problematic cart until I can no longer remove the error message.
I went to a site where someone said that it was a cart(s) that was not seated correctly. I was thinking that this could be the problem, but I could not get to the carts without manually moving the carriage over to the middle. I decided to take a chance and move the carriage (print head) by hand. Well, everything seems to be working!! But I must say that all this has been very strange.
Thank you.
YW
Glad to hear things are working again!
Redbrickman
Brother MFC-L8690-CDW
Well as far as the Registry problem goes one has to remember where MS is involved there is always a high percentage of failure ;)
One of the best oxymorons I ever heard...
Microsoft Works :lol:
OK Win 7 is pretty stable, and so it should be, after MS spent a few years playing with the prototype that had multiple problems, otherwise known as Vista :D
Glad you are now up and running again.
