HP laserjet 5100 cloudy
the prints of england
Print Lurker
hp laserjet 5100
the first image is printed on regular paper immediately after the second image on the same printer.
the second image is printed on DI-LASER film and has some blurring or watermarking.
the printer is a HP Laserjet 5100.
I'm trying to figure out what is causing the bleeding issue.
DI-LASER film
A light sensitive film (not paper) that uses a medical dry laser printer in a two step process to print xrays.
  1. A laser light is used to "expose" the film with the desired xray image file.
  2. Heat is then applied to "develop" the film.
This tech replaces wet/aqueous silver solution printing of xrays. Very cool.
Very different process than a home/business class typical laser printer like your HP Laserjet 5100. You are bound to have different printed results.
See Page 3 for a brief explanation of the process of these dri laser printers.:
https://www.medwrench.com/documents/view/3460/fujifilm-drypix-7000-fujidry-laser-imager-brochure
Print Lurker
hp laserjet 5100
thank you for the response. what i'm using is DI-LASER film from Davis Int.
https://www.davisint.com/product/dilaser-premium-laser-film/
Googled "DI-LASER film" and that's what I got. Printing with laser beams sounds more fun than an ordinary laser printer. :idunno
Good luck with your printing.
Print Lurker
hp laserjet 5100
i guess it's a proprietary Davis product. I've had this issue before but not consistently. an ordinary laser printer still uses lasers!
Print Lurker
hp laserjet 5100
i believe so. there's a rough side and a smooth side. i print on the rough side.
Yes, lasers are used. But very different processes.
Home laser printer
https://www.explainthatstuff.com/laserprinters.html
Medical dry laser imagers
Use a photosensitive film that the lasers applies it light directly onto the film creating the image. The film then travels over a drum that heats the film to develop the film image. No toner is used.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3137864/
Very different ways the two printers use a laser to create an image.
