I have an HP1280 printer. I have been using refills for this printer but since I started using it, a screen error that says "Print Caritirdge is Installed Incorrectly" appears every now and then.
Without doing anything on the printer, and by just closing the screen error, the printout will proceed just fine.
I inquired to a friend of mine who works on an HP repair center about this. He said that HP designed it to make it a hastle for those using refills but will not show that error if you use an orginal.
Has any body found a way to bypass this error ?
