I just thought that I might pass on this little thing that happened to me.
A long post
I have multiple Canon ip4200 printers. My wife has one, I have one, and we have a spare. Mine and my wife's printers have very heavy use, the spare just sits there most of the time and I print something on it from time to time just so it does not drop dead.
After wearing out the print heads on my wife's computer, we recently replaced it with a new print head, then I was not able to keep the print head in my printer working I also just replaced the Print head with a new one. The print head in the spare printer was acting up, constantly clearing what appeared to be plugged up nozzles, it started having ragged holes in the black pgi-5bk nozzle pattern, then after attempting to deep clean it, I lost all of the black nozzle pattern. No amount of cleaning would help.
At this point knowing that I would also have to buy another print head, I thought that I had better make sure that it was the print head that failed and not the circuit board. So I swapped the print head from my good printer into the spare, and put the print head from the spare into my good printer. Well I think that you are guessing what happened. The known good print head in the spare printer now printed a nozzle check pattern in the spare printer, but it was very ragged with holes throughout the pattern, just as it did before the old print head failed. And the print head that was taken from the spare printer and was put in my good printer, failed to print any nozzle check pattern on the black.
So I said to myself, well that proves that the print head of the spare was dead. So I switched both print heads back to the original places, figuring that I did have to buy a new print head for the spare printer. But oh Woe is me, when I put the known good print head back into my good printer, It continued to print out the same ragged nozzle print check pattern that it did in the spare printer.
My brand new print head now has very ragged holes in the nozzle check and will not clean up. My spare printer must have burned out a bunch of nozzles in the print head as soon as it was put in. Now I will have to buy another print head for my good printer and put this new blown print head into my spare printer. I doubt that I could ever trust a new print head in the spare ever again.
I think that I have shown that it is a bad circuit board. I recently had to replace the power supply on the spare printer because it suddenly stopped, refusing to boot up the printer. When it went it must have caused damage to the circuit board.
It has always been an advantage to be able to swap out parts between printers in order to prove out a problem. So it was a surprise to see this happen.
Has any one else had a similar occurance?
Jack
A long post
Jack
