easyrefill
- May 17, 2006
Epson printer is not the only printer that has a print head clog problem. But this is the one I know more about because I own over half a dozen Epson printers.
The first reason for clog is the printer is allowed to sit for a long time with printing. Ink will dry and dry ink clogs.
The second reason is due to the use of poor quality cheap inks. This one give Epson unfair blame because the people who complained about the clogged printer seldom mention the ink they use. I have someone asked me for help after using a cheap ink from China and have the printer not printing at all.
Incidentally, I have used the same inks from this manufacturer and I was prompted to stay away from the pigment made in China. I think eventually, the Chinese inks will get better and will be acceptable. For now, I rather stay away from it.
The third reason for clog is letting the printer cartridge out of the printer for extended amount of time. The advise is not to remove the cartridge even if you think the cartridge is empty. Some ink is better than no ink at all.
These are the reasons I can think of that will cause print head clogs. I will write about the three methods that can be used to clear print head clog on a different date.
