Trigger 37
- Dec 23, 2006
From Frustrated i960 Girl
Hi I hope you can help. I love this printer, but would gladlly replace it if newer generation stuff was as good! So I keep trying to fix it!!!
History:
Started to have print banding in magenta, tried to clean, deep clean, water, windex & alcohol the printheads, looked like brief improvement, then both yellow and magenta Nozzle test revealed no pigment coming from those 2. Tried more deep cleaning, then overnight soak in alcolol, and tried to follow instructions from others on this site, and opened the printhead (gently, did not stretch the orange plastic thingy) rinsed with more water and alcohol. Blotted everything dry with paper towel, and closed it up.
Here is where the real problem started. Put back in printer, and powered on. Got green followed by 5 orange repeating message. Tried to get it to head clean, or print anything. No Luck, just 5 orange blinks. Ordered brand new printhead from Canon. Arrived today. Hopes shattered. Changed it and got same message.
Tried to get into service mode on printer ie (resume/power release resume, but hold power resume 2x, then release). It still continues with pattern if the new printhead is in. If I take the printhead out and try to initiate the service prompts I get a solid green and the end of it, and get the right colors with each service command ie 0-green,1-orange, 2-green and so on-but nothing seems to happen, and certainly none of the printing comands will work since there is no printhead.
Have I completely fried the printer? Is there anything that can be done, and do you have any idea why the new printhead doesn't work?
Any help you could give me would be greatly appreciated. I rely on this baby so much!
Thanks
I need to know if there is any hope if
To: Frustrated960girl,...From Trigger
If you got a new printhead from Canon, and you still get the 5 orange flashes when you install that head, take it out and clean the contacts. Open the cover and when the PH comes to the center, pull the power cord from the printer and leave it out for 5 minutes. Put the power cord back in and close the cover to see if the orange flashes are still there. If they are still there you have to take out the printhead and clean the contacts. Each time you want to take the printhead out, remember to pull the power cord once the carriage is in the center. Now that you have the ink carts out and the printhead out you can proceed.
Since you never get anything but the 5 orange lights, the printer has not even tried to "Prime" the printhead as of yet. It still thinks it is a bad printhead because it is not getting the correct signals when it does the power on Diagnostics.
To clean the contacts, first just use some Isopropyl Alcohol and a soft cloth on the contact on the back of the printhead. Then do the same thing to the contact in the Carriage asm. Make sure you don't pull up on the cloth and only wipe down on the contacts in the Carriage ASM. Make sure you don't leave any part of the cloth or tissue on any of the contacts. Put it back in the printer and install the ink carts. Plug the power in and close the cover.
If it still continues to fail, check your purge unit to see if it is stuck in an extended position. When you open the cover and the head comes to the center, pull the power cord out. To the far right where the PH normally is parked are to pads. These pads are pushed up to the PH when it is parked to keep the nozzles from drying out being exposed to air. The purge unit is what controls this and locks the printhead in the far right. When the printhead move to the center, the purge unit cycles the windshield wiper blades (These are very small) forward and backward under the head when it is in the far right position to wipe excess ink off of the bottom of the printhead. The purge unit also contains a very small vacuum motor that sucks ink out of the bottom of the printhead through the nozzles. It does this in two cycles, one for black ink and one for colored ink. If any part of this mechanism is jammed or stuck in any position such that it will not cycle, this will also produce the 5 orange flashes. To clean the pads & purge unit you can use an eye dropper to squirt some windex or water onto each pad such that they are flooded. Check the wiper blades to see if they are stuck extended. If they get too much ink on them they can jammer under the far front and just stay there. There is a spring that is supposed to pull the wiper blades back to the home position but it may have come off or broken. If things look very gummed up with ink in that area you can spray some Windex on it to see if you can dissolve some of the ink. Don't worry about where it goes, it will just fall to the waste ink pads below. After all, this whole area is already full of black ink.
While you are in this area, use a flash light and examine the "Timing Strip". This is a long transparent film strip with 1000s of tiny black lines. The entire strip is 1/4" wide and goes through the back of the carriage asm. It is hooked at both sides of the printer. You want to see if there is any ink spots or dirt or dust on this strip that can mess up the timing of the printer. This can also cause the carriage error. The last thing to check is the carriage ASM itself. Try moving it back and forth when the power is unplugged when you've taken the printhead out. It should move smoothly and rather easily. It should not stick in any spot or be clogged with paper or anything else.
If all of this fails, call Canon where you purchased the printhead. They may send you another printhead or they may tell you that your logic card is bad, since that is the only thing we have not tried to correct. It can go bad just like anything else and if it is bad your next option is to buy a new printer since those cards cost much more than a new printer.
Let us know the results.
History:
Thanks
