- Thread starter
- #11
- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
Tin Ho:
Re: the fiber thing... That would make sense in a limited way but would more likely be a cause of ink freeflowing out, rather than air leaking in and that would seem to be born out by the posts on the subject of sponge shift, etc... in previous threads.
With a CIS if there's air leaking in you have a problem in the sealed loop and whilst I considered the printhead nozzles I realised they are so small that it would require a great deal of suction/vaccum to result in air being drawn in that way. Add to that, if that was happening the nozzle pattern would be interrupted by air bubbles blocking some nozzles, so I've come back to the the cartridge nozzles and the grommet on the printhead as the vector.
As if to prove the point further, wrapping the thin silicon tape, I found, around the nozzle and then piercing it, to allow ink to flow, has done the trick... so really this is more about finding a simpler more elegant solution as the silicon tape will undoubtedly stretch and tear over time.
Herky: MIS are right about the spongeless design on Canons.. if you think about it, the nozzle is big enough that ink will easily be replaced by air through the same nozzle that air is supposed to exit from so a spongeless design has to take that into account and so far none of them have.
Grandad35: Thanks for that... I did think that a light sanding grain might be the best approach and combined that with the silicon tape and so far it seems to have done the trick.
As to the o-ring I'll see about trying that, it's just finding one that is thin enough and wide enough, especially for the BCI-3 and PGI-5 carts such that you get a tight fit.. Experimentation is key I guess..
