Grey in nozzle check where it should be cyan!
JohnBB
Canon mg5350 & ts6250 & MX870
Title says it, really. Canon TS 6250 (European , if that matters.) Carts are PGI-580, CLI-581
Everyday document printing and I notice the colours are wrong, not blue enough.
First thought was the cyan cart was empty/dry/faulty, so did a nozzle check.
My prn [like many] does a grid of black with the main black [PGBK], and two shades of both cyan and magenta (deep and light) (and one of yellow and one of grey [BK]).
Now my prn is printing a deep and light grey instead of cyan. They are well printed, like the other colour bands, in fact the 'deep' grey [that should be deep cyan] is identical to the grey [BK] band.
The cyan cart definitely has cyan ink in it, and it is wet with it at the cart opening, I've checked! :)
Since the nozzle check is internal to the prn, it cannot be a printer driver etc fault, so can the internal processing have somehow mixed up the command to print cyan with the command to print grey?
Or what is happening? Any ideas on a cure, please? (I did search for a similar occurrence, but did not see anything here.)
Thanks,
John
Artur5
Kmt. 0.
MB5150, Pro10s,,Voron2.4
No, that’s impossible. Grey has only one row of nozzles (let’s call them big nozzles). Cyan has two channels (one of big of nozzles and one of small ones). Both rows are connected to the output of the cyan cartridge. If the problem was a rare ‘bug’ in the driver or firmware and the printer used ink from the grey cart instead of the cyan, it would eject the ink from the only grey channel (big nozzles) and both bands would be of the same intensity ( deep grey). Instead, you say that the bands corresponding to the cyan ink appear in different tones of grey (deep and light), meaning that the ink is being ejected by the two rows of nozzles corresponding to the cyan cartridge.
The most logical explanation is that there’s grey ink instead of cyan in the cartridge, but you said positively that this isn’t the case.
Nevertheless, to be sure, if you have a new spare cyan cart at hand (better if OEM). replace the current cart with the new one and see what happens.
If that doesn’t fix the issue, what can be then ?. There’s a very remote chance that the internal cyan channels connecting the cart to the rows of nozzles, developed a leak, because of a faulty rubber grommet and the cyan ink mixes with cyan. That seems unlikely because, in that case, both the cyan and grey bands on the nozzle check would be similar ( greyish-cyan, so to speak).
Another possibility is cross contamination on the bottom plate of the printhead. Grey ink is overflowing and covering the cyan nozzles. It could happen if the purge pad is dirty. I’d perform a cleaning cycle and clean the purge pad, wiping it with towel paper soaked in water. ( you'll possibly need the help of a flashlight and fine tipped tweezers). Anyway, first of all, please follow @The Hat’s advice. Upload here a scan of your nozzle check.
JohnBB
Scan attached.
I took the cyan cart out and pressed the paper with the nozzle check against the wet pad, I then smeared the resulting very dark mark with a damp cotton bud.
HTH
I have never seen anything like this before, in the first cyan block the colour Cleary looks to be grey, but on closer examination in Photoshop the grey colour is made up of magenta, cyan and yellow..
What I’d do is uninstall the printer driver from your system, reboot and then reinstall the driver again and see if that fixes the problem, because the cyan colour is flowing properly, it’s just the output from the cyan block prints grey, suggesting a software issue..
It wouldn’t hurt to flood the purge unit and run a cleaning cycle and see if the nozzle check improves.. Remember to power off the printer with the computer..
JohnBB
Thanks. It'll be a while before I get all that done, but I'll come back when I have something to report. OOI did you also do the photoshop analysis of the band that is supposed to be grey? I'd be interested to know what it says.
thebestcpu
Epson SC P900
Hi John
To get the best analysis of that nozzle check print, the best result is where the scan is of a clean nozzle check without a secondary nozzle check printed on the backside of the paper. Also, if you could do it in PNG format, it would be pretty helpful as JPEG artifacts interfere with a good analysis. For example, here is the Hue map of your image, which is very blocked up, indicating the JPEG artifacts and/or the slight color change from the nozzle check on the back of the paper.
Just a suggestion
John Wheeler
The nozzle check that was posted was more than adequate to see what the initial problems were, there’s no need to add more complications to the O/P situation..
JohnBB
So... I did a new nozzle check on clean paper, having set the output of ScanGear to be .png.
And what do I get?
A near-perfect (to my eyes) result, complete with Cyan bands as they should be. Bizarre!
Here's the scan, and at 600dpi this time.
If cross contamination is bad and leaking takes place for several days, the leaked ink can enter the cartridge of the affected colour. An often seen cross contamination with old Canon printers is dye black entering the yellow nozzles and the yellow cartridge. Here are two Canon CLI-8Y cartridges one OK and one contaminated
, click to enlarge:
This post shows cyan contaminated with magenta. Notice the dull contaminated cyan. I cannot determine if your cyan is contaminated but I think so. Cross contamination can happen between many colours, Here is another example from an iP4300. Notice the difference before and after a printhead cleaning, just like with your printer.
You can continue to use the printer as long as you can clean the cyan nozzles, but be prepared to buy a new printhead or a new printer soon.
Your new scan of the nozzle check is a much better quality. By zooming in on your nozzle check for dye black (BK) I notice double contours for the vertical bars meaning warped nozzles causing a fuzzy print in BK. This ruins photo printing. See this post.
Here is your BK test for comparison:
If the printer is in good condition apart from the cross contamination I recommend replacing the printhead, Do only buy printheads from a regular dealer of Canon spare parts. Don't buy from Ebay, Amazon, Alibaba or similar sites even if the prices are low. The printheads are used and most likely defective and have been cleaned to look like new.
