I posted a few days back about having occasional trouble when using the German method on the big 220Black tanks of oversaturating the sponges. Good advice was given and I than you all. Now, the new fun...
I decided to pay more attention when filling up my 220Black cartridge and I have made some new observations:
1) Cartridge is opaque except for the sides of the storage tank (duh) and a small strip along the bottom starting at the chip and ending just inside the spongy area. Qeustion: should i break down and buy some of the totally clear cartridges I have seen for sale just to make life easier?
2) I noticed when refilling, that I can see the tip of my syringe in that clear area on the bottom of the cartridge. Now, follow my landmarks here and this will make more sense. If you start at the chip on the cartridge and move in, there is a square depression, assumibly this is where the ink lvl sensor goes. Then there is a shallow rectangle with a square in the center. I believe this is the "prism" that the ink sensor looks thru. Next is a shallow elipse with a shallow circle in the near end. Now, I have found that if i position the tip of my syringe in the area of this shallow circle, 95% of the time, my refills go off with out a hitch... The exception being the 220Blacks. Last night when refilling one, places the tip of the syringe at the same point I normally do and I observed that the ink pooled at the tip and then "walked up" the syringe into the spongy area. This was a new observation. I took the syringe out, waited a few minutes, and tried again. Same result. Waited again... Long story short, I put over 5ml of Black into the cartridge, and not a drop of it went into the tank of the cartridge even though the tip of the syringe was over the tank area.
Highly annoying...
So, just curious if anyone else has noticed this and might have a thought on it.
Have a good one...
Highly annoying...
Have a good one...
