- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
I have noticed since my Pro 1 had it’s firmware up-graded, that there are no real improvements
that I can see for the print owner, except on the dark side there are a few which involve the
ink monitoring, ink wastage, sorry (Cleaning) and new pop-ups.
I’ve run the printer for more than twelve months with no ink monitoring and have gotten use to
the higher than normal purging/cleaning cycles and that is to be expected.
Since the new upgrade I have used the printer for a further 3 months without ink monitoring enabled
and the cleaning cycles have gone up considerably.( No Sh*t Sherlock)
But now I am using proper chips and the ink monitoring has been restored once again back to normal
but the clean cycles have stayed much the same (Excessive) in my opinion and the only notable
change to the printer is this darn firmware upgrade.
So if you guys get an offer to upgrade your firmware for whatever reason DON’T do it,
because it’s a bet it will also contain this new improved (Waste ink) feature..
