Epson WF-7510 feed problem
eppyson
Epson WF-7710
Need help fixing a problem with an Epson WF-7510. When printing on 13x19 semi-gloss sheets, the feeder stops advancing the sheet during the last 1 to 2 inches of the sheet, causing that portion of the print to be botched. See examples below. I carefully removed the roller assembly that sits just below the print heads near the sheet output, but couldn't find any obvious malfunction. Put it back in, and problem continues. It almost seems like it could be a software problem, like the printer "thinks" the sheet is already fully fed through - so, like the feeding and the printing are out of sync with each other somehow. I've got the latest printer driver installed. Any suggestions?
