Steve-O
- Mar 26, 2022
- Epson Stylus Pro 3880 & R1900
I have an Epson Pro 3880 and I have modified the oem carts as directed by Jose Rodriguez on his informative YT channel.
The printer recently developed the yellow/black contamination problem after the MK to PK swap so I am in the process of stripping and cleaning the ink system and whilst I have the covers off I would like to modify the cart chip system to an auto reset system.
I had been using after market carts but I was disappointed because a couple of the carts leaked ink into the cart holder bays (yellow, lbk & cyan). It looks like the ink was making it past the cartridge rubber seal and the cellophane where the cartridge bay nozzle enters the cart. With these carts you need the oem chip which you place under the auto resetting aftermarket chips.
Now the oem carts are more substantial with their seals and the cartridge bays showed no leaks with those. The idea of containing the cart ink in a bag with little ink surface to air appeals also so I have therefore modified the oem carts.
My main question here is does anyone have knowledge about using "Cartridge Chip Decoder For Epson Stylus Pro 3800 3880 3890 3885 Printer 9 color" as can be found on the internet? I have coupled the oem chips to the aftermarket auto reset chips with success and all my carts report full. Now it looks to me that I can do away with the oem chips and the aftermarket auto resetting chips by using this chip decoder strip (which would be a neater solution) and I would simply need to place the ribbons from the chip readers into the relevant position on the decoder chip....could it honestly be that simple? If so this would allow me to use carts without chips!!
I am hoping for some information on this before I go ahead and invest in some.
Kind regards
Steve-O
Kind regards
Steve-O
