Epson 1500w
Rec
Print Lurker
Epson1500w/canon8400se/koni220
I have some issues with an Epson 1500w i have change the ink from dye to pigment and the company that did the switch did not gave me a color profile. Dose any body uses this printer with pigment ink ? The colors are very off and the yellow is very greenish. I NEED HELP !! in my area i found nobody that can calibrate the printer or make me a color profile !!
If someone is using the same printer and can send me some color profiles I will relay appreciate it!!
Edit:
Since this is a non-standard setup there are no profiles available even less for an unknown ink on unkown papers.
You should find a profiling service in your country - some offer their service even via Ebay, or contact your supplier of inks, some of those distributors offer a profiling service, or companies selling papers offer a profiling service as well., and there are color mangagement consultants which offer a profiling service as well. It all depends very much of your country of residence which is not visible to me.
