Fenrir Enterprises
- May 17, 2006
I bought a "barely used" 1400 that had been sitting in someone's attic without ink carts for several years (it's in the old white and blue box). I have a refill damper kit (not CIS, just the refillable dampers) and reset chip with button rather than manual/auto reset chips. Since it hadn't been used in so long, I decided not to even bother refilling it without cleaning it thoroughly, so I bought a set of blank dampers to use with cleaning fluid. The first few times I turned it on, it would allow me to run head cleanings, but if I tried to print it would go to "General error". I thought, great, the thing has been used until the waste counter filled up. I double checked everything and the carts were reading "unknown" so the chip may not have been seated properly. I redid it, the carts showed up as "Epson", but it still kept zapping back to "General error".
I left it overnight (I'm working on it where I work and not at home) and when I got back it started up and I was able to get it to print after completely deleting the print spool. I ran several head cleanings and purge pages... and then it went back to General Error when I tried to run another head cleaning after letting it sit for half an hour. I turned it off and it wouldn't turn back on, I unplugged it for 10 minutes and it came back to life. So I downloaded the WICReset tool from OctoInkjet to check the counter to make sure it hadn't been run into the ground. It came back as only 17% full... they used it more than they said they did but still barely enough to make a difference (and now I'm not worried about the waste pads overflowing). I ran the advanced diagnosis part of it and I saw the "head ambient temperature abnormal". Huh. Maybe it's still got dried ink in it and I should just keep running cleaning fluid through it for the rest of the day. Anyone else have any ideas?
