Dye based and pigment based ink
pally
Can you use dye based ink to refill a cartridge, which had pigment based ink in it? what happens if i start refilling all cartridges with dye based ink? :)
pally
Yes is the simple answer, but use good quality inks.. :)
pally
So what happens if i fill everything with dye based ink?
Pally
The printer will print as normal, but youll have to clean out the cartridges if you want to use pigment ink in them again.
Question:- why dont you want to use pigment inks whats wrong with it.. :|
pally
It seems to be more expensive
Pally
When buying third party inks compared to OEM inks they are so much cheaper, so a little extra is not much to pay for the better quality.. :)
