Computer can't recognize my Epson 3880
Alan Baily
Epson Stylus Pro 3880
I haven't printed in a while (9 months?). My printer turned on OK but my computer won't recognize my printer. I believe this is the first time using the printer with this relative new computer (less than a year old). I am trying to print an excel document. I downloaded the latest drivers. I went through all the steps that Windows suggested. I talked with someone at Epson and went through all those steps. I have yet to see anything in Device Manager. I tried different ports, different cables. So far nothing. Somehow, I think, the drivers aren't getting to the place where the computer can recognize them. Just a guess. Anybody have any other ideas?
thebestcpu
Epson SC P900
Hi @Alan Baily
You did not mention the connection type: USB, Ethernet, or Wireless
The following is a list of steps (you may have already completed some). I cannot confirm this list, as I use a Mac, but I thought this might be of some help. Take all such lists with a grain of salt when not confirmed.
John Wheeler
Epson Stylus Pro 3880 - Windows USB Recognition and Driver Fix Steps
baseline info:
The Epson 3880 uses a USB 2.0 interface and a legacy printer driver that’s not natively included in Windows 10/11 anymore.
When you plug it in:
You should see some sign of connection (e.g., “Unknown USB device”) in Device Manager.
If you see nothing at all → Windows isn’t detecting any signal on USB — driver installation can’t proceed.
That means it’s one of:
Faulty USB cable or port (most common)
Faulty printer USB interface board (some 3880s develop this after long storage)
Windows not loading the driver INF correctly because of driver signature or permissions issues
1. Confirm Hardware and Cables
- Use a short, shielded USB 2.0 cable directly to a USB-A port.
- Avoid USB hubs or long cables.
- If your computer only has USB-C ports, use a known-good powered USB-C → USB-A adapter.
- Turn the printer ON.
- Open Device Manager → View → Show hidden devices.
- Expand "Printers", "USB controllers", and "Other devices".
- If you see “Unknown Device” or “USB Composite Device”, uninstall it and reconnect the printer.
- If nothing appears or disappears when plugging/unplugging, try:
- Different cable
- Different USB port
- Different computer
- If no computer reacts, USB board may be defective.
2. Clean Old Driver Entries
1. Disconnect the printer.
2. Uninstall all Epson software via Control Panel → Programs and Features.
3. Run “printmanagement.msc” → All Drivers → delete any Epson Stylus Pro 3880 entries.
4. Reboot the computer.
3. Download and Install the Correct Driver
1. Visit Epson’s official support page:
https://epson.com/Support/Printers/Pro-Imaging-Pro-Series/Epson-Stylus-Pro-3880/s/SPT_C11CA16201
2. Download the “Drivers and Utilities Combo Package” for your Windows version.
3. Right-click the installer → Run as administrator.
4. Only connect the printer when prompted.
5. After installation, open Control Panel → Devices and Printers → confirm Epson Stylus Pro 3880 appears.
4. Handle Driver Signature Blocking (Windows 10/11)
If the driver won’t install:
- Go to Settings → Privacy & Security → Windows Security → Device Security → Core Isolation Details.
- Turn “Memory Integrity” OFF.
- Reboot and reinstall the driver.
- You can turn it back ON after successful installation.
5. Manual INF Driver Installation (if Needed)
If the installer fails:
1. Unzip the downloaded driver package.
2. Locate the file “epson3880.inf”.
3. In Device Manager → right-click the Unknown Device → Update Driver → Browse my computer → Let me pick → Have Disk.
4. Browse to the folder with epson3880.inf.
5. Select “Epson Stylus Pro 3880” and complete installation.
6. Test Network Printing (Optional)
If the USB interface fails but printer powers up normally:
1. Connect printer via Ethernet to your router.
2. On printer: Menu → Network Settings → TCP/IP → find its IP address.
3. On Windows: Settings → Bluetooth & Devices → Printers & Scanners → Add Device → Add Manually → TCP/IP printer.
4. Enter the IP address and choose the Epson Stylus Pro 3880 driver.
7. If USB Hardware Is Defective
- The 3880’s USB interface may fail after long storage.
- Replace the “Main Board Assembly” (available used online).
- Or continue using Ethernet network printing.
Summary Table
| Step | Action | Goal |
| 1 | Verify cable/port/computer | Confirm USB detection |
| 2 | Remove old drivers | Avoid driver conflicts |
| 3 | Install Epson driver | Register correct driver |
| 4 | Disable Memory Integrity | Allow legacy driver |
| 5 | Install manually if needed | Force INF recognition |
| 6 | Try network port | Verify printer hardware |
| 7 | Replace board if needed | Restore USB functionality |
Alan Baily
Thanks for the quick thorough response. It is a USB connection. It might take a few days work through all of this.
Alan Baily
Good news and bad news. I got the computer to recognize the printer. I fiddled some more but think that I tried Windows 10 drivers that made the difference. Not quite sure. Bad news. I can't get the Excel file to print. It's been awhile since I've printed with the 3880. Am I missing certain steps to go through? I went through the Windows Printing Preferences and revised. Did I miss something?
thebestcpu
Epson SC P900
Have you printed anything to that printer yet as it was not clear from your post? If you have not printed anything yet, use this "print test page" approach to verify the system can print to the printer.
If it does print to the printer, then this could be something from within Excel instead of your system/printer.
Here is a link to how to print a test page: https://help.nextar.com/tutorial/how-to-test-print-on-windows
Alan Baily
Thanks for the info. I was able to make a test print. Is the info on the test print important or should I, as suggested, just go back to Excel and see what the issue might be? One more thing. In Windows, the printer properties dialog box does not show the ink levels in color, just in grey. Does that mean anything?
thebestcpu
Epson SC P900
Not sure about the grey for reporting the color ink levels. I found this on the web to check:
Confirm via Epson Printer Utility
Open:
Start → Epson → Epson Printer Utility 4 → Stylus Pro 3880
Then click:
EPSON Status Monitor
If the utility shows color ink levels, communication is fine — the grey boxes in Windows are just cosmetic.
If the utility also shows grey boxes or “Cannot communicate with printer”:
The driver is still not talking to the printer.
Then in regards to checking out Excel, here are the printing dugging steps worth trying:
Excel Printing Debug Checklist (when Test Page Works but Excel Won’t Print)
1. Confirm the Printer Selection
- In Excel: File → Print → Printer name.
- Make sure it explicitly says “Epson Stylus Pro 3880.”
- If it lists something else (e.g., “Microsoft Print to PDF”), change it.
- Try toggling to another printer, then back to the Epson 3880.
2. Try a Different Workbook
- Create a new blank workbook.
- Type a few words in cell A1 and print.
- If this prints, the issue is in your original workbook’s print setup.
3. Clear Print Area & Reset Page Setup
1. Open the problem workbook.
2. Page Layout → Print Area → Clear Print Area.
3. Reset page settings:
- Margins → Normal
- Orientation → Portrait
- Size → Letter (or your normal paper)
4. Save, close, reopen, and check Print Preview.
5. If preview now looks right, the print area was corrupt.
4. Start Excel in Safe Mode
- Close Excel.
- Press Windows + R, type: excel /safe → Enter.
- Open your file and print.
- If it prints, an add-in or printer registry entry is corrupt.
- Exit Excel.
- Delete this registry key:
HKEY_CURRENT_USER\Software\Microsoft\Office\<version>\Excel\Options
(Excel rebuilds it automatically.)
5. Test with Another Program
- Try printing from Word or Notepad.
- If those print fine → Excel-only issue.
- If they also fail → spooler or driver issue.
6. Repair Excel Print Configuration
- Close all Office apps.
- Control Panel → Devices and Printers → Epson Stylus Pro 3880 → Printer Properties → Advanced → New Driver.
- Re-select the correct Epson driver.
- Reboot and try again.
7. Print to PDF (Pipeline Test)
- File → Print → Microsoft Print to PDF.
- If this works, Excel’s output engine is fine.
- Reinstall the Epson driver to restore the link.
8. Restart the Print Spooler
- Press Windows + R → type services.msc → Enter.
- Find “Print Spooler” → right-click → Restart.
- If needed:
1. Stop the spooler.
2. Delete contents of:
C:\Windows\System32\spool\PRINTERS
3. Start the spooler again.
9. Run Office Repair
- Settings → Apps → Microsoft Office → Modify → Quick Repair.
- If that doesn’t work, try Online Repair (preserves your files).
10. Re-establish Excel Defaults
- Close Excel.
- Rename or delete this folder:
C:\Users\<you>\AppData\Roaming\Microsoft\Excel\XLSTART
- Reopen Excel to rebuild a clean startup profile.
Summary Table
| Step | Focus | What It Fixes |
| 1 | Confirm printer | Wrong printer selection |
| 2 | New workbook | Corrupt file |
| 3 | Clear print area | Invalid print range |
| 4 | Safe Mode | Add-ins or registry |
| 5 | Test other apps | Confirms Excel-only issue |
| 6 | Rebind driver | Stale printer configuration |
| 7 | Print to PDF | Output pipeline check |
| 8 | Restart spooler | Stuck queue |
| 9 | Office Repair | Damaged Excel install |
| 10 | Reset startup | Template corruption |
Alan Baily
Sorry for lack of response. Life is very busy and will be gone for a week for Fall Foliage photography in the Catskills and Finger Lakes (NY).
Music Lover
Brother J1010dw
It seems that my friend has met such a problem in the past. We searched on the internet and called the seller, tried the instructions below, and then made it work again. You could have a look at the reference.
The first one is to restart the print spooler service. Press Win + R, type services.msc, and press Enter. Find "Print Spooler", right-click, and select "Restart"
Or force Windows to look for your printer. Open Device Manager. Click "Action" in the top menu → "Scan for hardware changes" (This makes Windows actively search instead of waiting to notice your printer)
If they could not help, what about trying a "clean" reinstall? Remove the printer from Settings → Bluetooth & devices → Printers. Shut down your computer completely (don't just restart). Unplug the USB cable from both ends, then reconnect. Turn your computer back on.
Also, are you using the original USB cable that came with your printer? Some cables only charge but can't transfer data - I made that mistake once!
If none of this works, the Microsoft Printer Troubleshooter (Settings → Update & Security → Troubleshoot) sometimes finds issues that the regular Windows suggestions miss.
Good luck - hope one of these does the trick!
