- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
First off, if you want to print your snap shots then just get yourself an inkjet printer and some glossy paper, it doesn’t matter what brand of printer it is or how cheap it is it will do the job.
Now armed with your new printer use one of the many photo Apps. That comes with just about every printer or simply Wi-Fi your snaps to the printer. (Much better)
Follow the easy instructions in that App./printer setup and then click print, you will be surprised at just how easy it is and your photos will look just amazing, it’s nicer to have a physical photo in your hand than in your phone.
Now if you want to go further and improve your ability to take and print better photos then you’ll have to sit down and learn the whole new world of digital Photography and printing, easy it is not, the learning bit I mean.
You have just proved that it’s not rocket science it’s just a matter of Snap, Click, Print that’s it, BUT if you’re not prepared to learn the hard way then just stick to what you know best and be happy with the results.
Now don’t go waisting you money on expensive cameras or printing equipment until you’ve made that clear decision to “LEARN”, till then the cheap printer and iPhone will enable you to experiment with all the different ideas that are floating around inside your head.
Now if your still unhappy with your results then this is where the BUT comes in, borrow a good camera and try out some new ideas with it, then return home and just print out your results and this stage don’t change a thing, stick with default setting.
If this is you and you’re now hooked on photography then go and enjoy this new world out there that’s just waiting for your own inspiration to show it off, good luck..
