AmaDeuSbg
- Aug 15, 2023
- EPSONS: L1300, L805,L850,L1800
Hello,
I have been on a quest of finding my first bigger printer. So far I have only used Epson printers (L805, L850, L1300, L1800) and this will be my first Canon. I was hesitant at first because I looked Epson's T2100 which was reviewed by Ink stained Fingers but the absence of auto reset chips kind of made me search more. I am not willing to give 1800 euro for the inktank version so I decided to check Canon. At first I saw the TC-21 (which is also similar to the TC-20, which was mentioned here in the forums and by Keith Cooper as a good starter both in terms of colors and form factor).
Since I was already looking at Canon I decided to check their other printers. I was generally looking for a little more expensive machine but with lower ink cost (because I was thinking to go with original inks for simplicity). I noticed (I hope I got that right) that the main difference between the TM-*** models is the ink cost and the size and I noticed the TM-255 ink is generally not so expensive compared to the TC-21 ink. I contacted a Canon seller in my country (Bulgaria) and asked for a test print because I was also curious if t he lower resolution (keep in mind I am coming from desktops) will be good enough for my taste in general and I was also curious of the colors will be OK for my taste (it is 5 colors machine - BK MBK C M Y).
So now the questions add up:
* I received the print - overall I was happy with details but the whole image had a magenta tint. The salesman I spoke told me that If I profiled it will be better (because they actually printed the test in one of their clients shop) but yet again I wonder if that is just not a limitation of the machine because the grey puzzled me how good it looked. In addition I saw that Canon even has ready made profiles for their papers which is also puzzling why (presumably) the shop that printed the test does not use them? The guy that delivered the test print mentioned they did not even use a graphics software to print it but probably some app or something so this can also affect the print but still I wonder if this is the case?
*My main goal is to print canvas and photo papers (like silk and luster papers, rarely pure gloss). I recon I saw somewhere that a guy told that the longevity of the ink was not very good on canvas indoors with high lighting conditions and you can visibly see fading after couple months. I am aware that this is highly depends on the media you use but I though that pigment inks (especially original ones) are more durable but I thought at least that indoor use will not be a problem. Does anyone have experience with the ink that the machine uses or any feedback on the possible performance of the ink, this will be highly valued.
Generally, I am looking for 60cm (24 inch) machine with relatively cheap (the ink will actually be like 0.45euro per ml for the TM-255) and the printer itself will be like 1100 euro (approx 900 euro after VAT deduction). So if there is a similar price range machine I will be really thankful if you guide me through.
I can either use the Canon made profiles on their site for the respective papers or make my own profiles (I have a colormunki).
Thank you all for your time and have a lovely night
