My 2 Canon printer S300 suddenly flash one yellow then one green at the same day. I did try: unplug power, USB, reset catridge but doesnt work...Please help !!!
Just got another one from Ebay, same thing happen when plug in...waiting for return it !!! lost $26 ...shipping. Asking Canonusa again, may be they again dont know how to reset it...
The error codes for an ip4200 are in my Canon ip4200 Service Manual. I know this isn't an S300, but it's likely that Canon have kept some continuity/consistency in the meaning of the codes ...
Is it
1. Flashing Orange - Green continuously with no pauses, or
2. Flashing O - G a number of times followed by a pause, then flashing O - G the same number of times, repeatedly.
If 1. the fault is "ROM Error on Logic Board Assembly".
If 2. count the number of Oranges in each sequence {the possible faulty components are shown in the brackets}
2 Oranges = Carriage Error {Carriage Unit; Timing Strip Slit Film; Logic Board; Carriage Motor}
3 = Line Feed Error {Timing Sensor Unit; Timing Strip Disk Unit; Feed Roller Assembly; Platen Unit; Logic Board; Paper Feed Motor}
4 = Purge Cam Sensor {Purge Unit; Logic Board}
5 = Auto Sheet Feed Cam Sensor {Sheet Feed Unit}
6 = Internal Temperature Error {Logic Board}
7 = Waste Ink Absorber Full {Ink Absorber Kit}
8 = Print Head Temperature {Print Head; Logic Board}
9 = EEPROM Error {Logic Board}
10 = n/a
11 = Carriage Lift Mechanism {PR Lift Shaft Assembly; Sheet Feed Unit; Logic Board; Carriage Lift Sensor}
12 = AP Position Error {Sheet Feed Unit; Logic Board; Purge Unit}
13 = Paper Feed Position Error {Sheet Feed Unit; Logic Board}
14 = Paper Feed Cam Sensor {Sheet Feed Unit; Logic Board}
15 = USB Host VBUS overcurrent {Logic Board}
16 = Valve Sensor Error {Purge Unit; Logic Board}
17 = Motor Driver Error {Logic Board}
18 = n/a
19 = Ink Tank Position Sensor Error {Platen Unit; Logic Board}
20 = Other Hardware Error {Logic Board}
