Canon Pro-100 New Drivers.
Roy Sletcher
Indolent contrarian
Ottawa, CANADA
Canon Pro-100, and Epson 3880
I note from some of the other Printer Forums I visit that the "chattering participants" are commenting on new drivers for the Canon Pro-100.
One item mentioned is additional Media settings - including "Matte Paper N", or some thing like that!
Visiting the Canon USA website, I note several newer additions than my current driver. True to form Canon's information and documentation was anything but clear and concise.
In fact I would describe it as "incoherent", if I could spell the word.
Any views or information on the newer drivers from our resident guru's?
Attached is a pdf of my current printer settings.
Any advice appreciated.
RS
  • Printer Info.pdf
Hi Roy,
I would recommend you just ignore the new driver, that’s if you’re perfectly happy with the one you got right now, if it’s not broke then why bother fix it, it’s like chasing elusive butterflies.
I must say that I have never upgraded any of my Canon print drivers from the ones that I used for the original installations back when Adam was a boy; I found the grass is only greener on the other side till the darn cattle eat it all up.
My two cent worth from a different point of view.. :caf
I am going to side with @The Hat on this. IIRC, The Hat was burned on a Canon update that created more ink wastage than before the update. Unless something specific is fixed that was malfunctioning on you or there is new functionality you need, then do not update. Newer is not always better.
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
This one??
Thank you for using Canon products.
Canon has released a firmware update for the Canon PIXMA PRO-10/PRO-100 printers in order to address the phenomenon described below.
Canon takes pride in the quality and performance of its products, and we offer our most sincere apologies to customers using this product who have been inconvenienced by this phenomenon . We hope our efforts will earn your understanding.
Affected Products
DetailsPrinter Firmware Updater incorporates the following:
    1. Fixes a phenomenon in which the ink level in the ink cartridges for the printer is not properly indicated in some instances.
Printer Firmware Updater for PRO-10 printers contains the Firmware file Version 1.030. If the printer’s firmware is already Version 1.030, it is not necessary to update the firmware.
Printer Firmware Updater for PRO-100 printers contains the Firmware file Version 1.020. If the printer’s firmware is already Version 1.020, it is not necessary to update the firmware.
Print the nozzle check pattern to determine if firmware update is needed.
Printing the Nozzle Check Pattern:
1. Make sure that the power is turned on.
2. Make sure that one or more sheets of Letter-sized plain paper are loaded in the rear tray.
3. Open the paper output tray gently, and open the output tray extension.
4. Print the nozzle check pattern:
(1) Hold down the RESUME/CANCEL button until the POWER lamp flashes white twice then release it immediately.
(2) The nozzle check pattern will be printed.
(3) The Firmware version will be listed on the bottom of the nozzle check pattern sheet.
When updating your printer’s firmware, please first review the instructions thoroughly before you download the firmware.
SupportThis information is for residents of the United States and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region. Please register your PIXMA PRO-10 or PIXMA PRO-100 printer. By registering, we will be able to notify you via email when service updates are available.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone:1-800-OK-CANON
1-800-652-2666
TTD:1-866-251-3752
Email:carecenter@cits.canon.com
For additional support options: www.usa.canon.com/support
