Canon pro 10 banding
Norbert
epson r 2880
Hi all
I have a problem that I can't explain other than by descriptive photos . whether i print with PrintFab or with the Canon xps driver the problem is the same .
Printer : canon pro10 s ( 2 years old)
cartridges : OEM
inks : octoinkjet
what do you think ?
Thank you
I’d suggest you try giving the time strip a clean on both sides and then give it another go at a print. Failing that give the grey carts a good clean, and then refill..
P.S. Question;- Why do you use the xps driver, it doesn’t print any better than the standard driver..
Norbert
epson r 2880
thank you , how to clean the strip ?
Soak some window cleaner in a small piece of paper towel and gently rub both sides, end to end, and it might be better to pull the plug to allow you to move the print head manually.. Go slowly and gently, and patients can help too..
P.S. I broke mine from carelessness and not taking my time..
I can report that I'm getting fine banding with the Printfab driver with various Epson printers - mainly in the highest quality settings
Norbert
epson r 2880
As recommanded by "the hat" , I cleaned the encoder strip and the grey carts , the problem on the last two images disappered , however the dark strip at the start of print is still there ( images 3 and 4 ) . I still have the problem of images 2 but only with this photo !!!!!????
Norbert
epson r 2880
I don't understand why I have banding only at the start of print and why the grey cart must be the problem , it's the same with color printing
Try purging the grey cart again , and if necessary do the same with the Photo black, and always remember to agitate the carts yourself before installing..
P.S. a good solution to use is warm water and a good couple of drops of window cleaner..
Norbert
epson r 2880
I cleaned and refilled my 2 sets of carts and the problem is still there . Could it be a paper feeding problem because there is a darker strip only at the start of printing in B and W or color ?
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
To eliminate the latter you could try to print with a large border (that's why Fine Art settings have this).
I observed occasional banding at the borders with octoinkjet GY too, you could buy an OEM cart.
