Hi, I've already done that 3 times unfortunately, as well as many cleans/deep cleans/aligns and everything else possiblebillkunert said:You may have to do the bottom plate cleaning procedure if your printer version has such a procedure. My MP600 does.
Thanks for the suggestions.dan_uk_1984 said:Mine does this ocasionally, I get a peice of paper and fold it in half and feed it through the roller cleaning process a few times, and stick a sheet of thick parchment type paper through and print a word doc with a full stop on every line at each side of the page.
Usually does the trick, if you print envelopes regularly then the problem should go away. I print postage now, and had smudge problems first off but now i do it all the time they are clean....
