Canon MP780 Extended Nozzle Check
1) Put paper in the Auto Sheet Feeder (even if the Feed Switch is set for the cassette).
2) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
3) Press the < key (also labeled -) once.
SERVICE MODE
TEST MODE
4) Press OK.
TEST MODE [1]-[8]
1: SYSTEM TEST
5) Press the > key (also labeled +) twice.
TEST MODE [1]-[8]
3: PRINTER
6) Press OK.
3: PRINTER
[1]SHUKKEN PATTERN 1
5) Press the > key (also labeled +) once.
3: PRINTER
[2]SHUKKEN PATTERN 2
6) Press OK.
The printer will print the extended nozzle check along with a bunch of other stuff.
7) Press the Stop/Reset button.
TEST MODE [1]-[8]
1: SYSTEM TEST
8) Press the ON/OFF button.
The printer will cycle power and be ready to go.
SpideRMaN
What should an Extended Nozzle Check look like ?
Thanks
Here's the MP780 Extended Nozzle Check:
Here's the standard Nozzle Check for the MP780:
SpideRMaN
Thank you !
Will an extended nozzle check fire more nozzles or just give more info then the standard one ?
Both nozzle checks are identical for the pigment black but for all the dye ink nozzles, the extended nozzle check lets you see each individual nozzle. The problem with the standard nozzle check is that it places multiple drops from different nozzles on top of each other and if you have a whole set of them missing you cannot tell.
So, no, the extended nozzle check does not fire any more nozzles it just fires all the nozzles mulitple times into a horizontal segment on the grid pattern so that you can easily verify that every single nozzle is firing and unclogged.
