Printer: Canon PIXMA MP510
Problem: Refilled all OEM ink cartridges
Ink level indicators read no ink in cartridges (Cyan, Magenta, Yellow)
Ink level indicator reads low ink in Black cartridge
Get message that "Ink may have run out, Do not print"
Solution: Override the system by using the "OK" button on printer.
Proceeds to print beautiful photographs and graphics.
Question: Does overriding the system cause problems for the printer?
Should I try to reset the ink level indicators to show 100% full?
( I don't mind visually inspecting the cartridges instead of relying on the readouts)
How do I reset the system? (Canon CLI-8C,M,Y and PGI-5BK chipped cartridges)
Should I use the empty cartridge then full cartridge method of resetting, found here on this forum, or is there a better method that I have missed?
Thank you,
Desordre
Thank you,
Desordre
