Canon Maxify GX5050: Dye Ink or Pigment Ink?
xwarer
Canon Maxify GX5050
Hi guys, I have a canon maxify gx5050 and I have to do 3-4k prints a day.
Searching on the internet I saw that pigmented compatible ink costs much more than Dye ink, my question is: is it possible to use dye ink in my printer?
Only if you want trouble, and if you wish to use dye ink then get another printer, compatible pigment ink is available at a very reasonable price, so don’t try to ruin a perfectly good printer..
xwarer
Canon Maxify GX5050
In Italy i pay 40 euros for 1 liter of every color kit for the dye ink, for the pigment ink it would cost me around 120 euros for the same quantity
I'm not clear what you want to acheive - swapping the pigment ink to dye ink in an existing printer or initializing a new printer directly with dye ink.
And I'm not clear about your ink pricing - they appear to be pretty arbitrary , I have seen Canon compatible pigment inks at a lower price.
And be aware that you are loosing significant long term stability/longevity by using arbitrary dye inks if that would be an issue for you.
I only can report from experience with Epson printers that swapping from dye to pigment ink on various Megatankprinter worked o.k. but problems - missing nozzles occured after the change from pigment to dye inks - it is apparently just not possible to clean and wash out the last pigment particle from the ink reservoir and tubing/ink supply system .
simondavidson
Atlanta, GA
HP
Yes, it's possible to use dye ink in your printer, but it's essential to ensure compatibility with your printer model.
Redbrickman
Brother MFC-L8690-CDW
3-4K prints a day is a lot of printing and beyond hobby use. If you are running this as a business then you need to factor in the cost of good quality ink and price your printing accordingly. Don't use cheap inks unless you want to risk losing a good printer.
