Hi guys new to the forum so looking for your help. I have had this printer for 10 months with no problems, when I bought it, it was 5 months old. I have used compatible cartridges from Novatech in all that time no problems. About 1 month ago I noticed the print were incomplete so I found your forum, read the posts on cleaning the printehad and, following instructions did so. This caused the printer to print all colours but not black on its own and part of the nozzle check pattern was missing.
As a result I decided to invest in a new printhead from the USA, 28 complete. In the meantime I decided to try again and followed the instructions on using compressed air in reverse, so after a thourough soak I gave it a quick spray of compressed air. My clean involved following Neil Slade instructions of removing the nozzles carefully.
I put the printhead back in, switched on and tried a nozzle check. This resulted in an incomplete print so I gave up and left it switched on. After about 30 minutes I noticed the printer switch itself off. This was strange as it had never done this before! I tried switching back on but when you push the power button on, the printer on the light goes green and when you let go it switches off after about half a second.
There is power there but it will not stay on, has anyone any ideas on what could be wrong? The printhead is seated correctly with full cartridges, albeit compatibles but I have never had a problem until recently. It does not have cartridges that are chipped so no problems there. No error messages are showing up either and no blinking lights.
In the meantime I have a new canon printhead with no Printer!! I have tried emailing Canon but they are less than useless!
cheers
