In all honest you will get slightly less waste because the printer will not be priming the cartridge as much because the printer will not be monitoring the ink levels in the cartridge once you disable the monitoring through the usual warranty void screen (assuming you get that still with the MX860).d1hamby said:Is there a program like this for a Canon MX860. If I get a CIS that works I'm sure the waste tank will fill up and I'll be in the same boat.
The chips I'm using don't require you to disable the monitoring.websnail said:In all honest you will get slightly less waste because the printer will not be priming the cartridge as much because the printer will not be monitoring the ink levels in the cartridge once you disable the monitoring through the usual warranty void screen (assuming you get that still with the MX860).d1hamby said:Is there a program like this for a Canon MX860. If I get a CIS that works I'm sure the waste tank will fill up and I'll be in the same boat.
That said, it is possible that the firmware will force the printer to do more cleaning so it's horses for course really...
Either way, I can tell you that Canon printers waste less ink than Epsons by a LOooooong way...
Remember that the printer design changed dramatically when the iP4600 came out.nche11 said:How long have you used the ip4600? It can't be older than my ip4200 which has not had a full waste ink tank yet. Did you do a lot of cleaning cycles? That sure is a speedy way to fill it up quickly. If you did then you want to ask yourself why you had to do a lot of cleaning cycles. Normally the printer will do it when it's needed. You almost never need to do it manually at all.
