- Sep 10, 2007
- Location
- Laramie, Wyoming
- Canon i960, Canon i9900
In a "past life", I dealt with machines that used a considerable amount of wet steam at high velocity to perform their function.
Erosion (mechanical pitting, similar to cavitation in centrifugal pumps) to of the metals of construction was an industry issue. Even the hardest metals would eventually erode and change surface geometry with constant use.
I have had several Canon printheads show evidence of mis-directed ink (lines above or below the proper grid location) upon examining service nozzle check patterns. This effected photo quality prints by producing fine streaking, particularly with certain color gradients. No amount of cleaning techniques or efforts would produce the original perfect grid patterns. Only renewing the printhead solved the issue.
My "past life" experience leads me to consider that the fine geometry of the inkjet nozzles is being disturbed by similar, albeit microscopic, erosive damage. I assume the base materials on the nozzle is silicon, no? The "boiling" of the ink in the nozzle is a very violent process in a very confined area, and could easily lead to this type of wear.
Any comments?
Wayne
Any comments?
Wayne
