Canon inkjet for occasional color prints — worth the clog risk?
thomasbrown
Canon i560
My wife and I both work from home, and our printing is mostly black-and-white documents a few times a week. We have a shared Canon inkjet that handles that fine, but color jobs are rare — maybe a school project or a photo every couple of months. The problem is every time we go weeks without color, I end up running cleaning cycles and burning through ink just to unclog things.
I keep seeing auto news and car-related pages suggesting more home offices are printing vehicle listings, spec sheets and photos, which made me think about how little color we actually need. Should I keep a Canon inkjet set up for the occasional color print, or add a cheap monochrome laser for daily pages and leave the Canon off until we truly need color? My concern is ink cost and printhead clogs sitting idle, but I don't want to give up color entirely.
Anyone running a similar setup with a Canon inkjet used only now and then? How do you keep the printhead healthy without wasting ink?
You have several options in your case - keeping a printer active and printing on a low and regular level is the best option to keep the printer in good working condition.
You may use 3rd party cartridges at very low cost
or you look for new hardware - a new laser printer - a color printer
or you look for a new inkjet printer - Canon or Epson or Brother or HP - of the Ecotank/Megatank type with pretty low ink charges, but such inkjet tank system printer needs to print as well on a regular low level.
I used to have a Brother DCP-j105 for a similar purpose, and it turned out that I print significantly less than needed by an inkjet printer. The only downside was ink being used for running the printer's cleaning programs manually every few weeks, but the inks themselves were only a bit more expensive than water so it didn't make much of a difference for me.
If I were you, I'd probably still take the risk - especially if you consider a printer that supports dye cartridges, they clog quite a bit slower and the carts themselves are cheaper. Just be sure to make an occasional print, or use cleaning programs to run the ink through the head every now and then
