I have a two year old i960 printer and recently have been having some problems with lines/streaks being seen in photos. I have been using both Canon and non-Canon inks and I see the problem with both.
When I do a nozzle check, all colors seem to print OK (although quite faintly - which I think is normal ?) without streaks that I can see. With the A-H nozzle checks, the 'G' pattern showed streaks....so I did a manual print head alignment. When the page printed out, I can select a "good" number associated with a pattern that shows no streaking for all except the "G" pattern. All of the patters for "G" from -5 to +5 show streaking. The +5 pattern is the best, but it still shows some spaces between the lines.
I called Canon and they suggested that I try and clean the print head. I have taken it out and cleaned the print head (and done the print head cleaning/deep cleaning from the i960 maintenance window) but the problem still exists.
Anyone seen this? Also does anyone know what exactly the A-H nozzle checks are checking? Horizontal alignment? Veritcal alignment? The Cyan/Magenta have three patterns and there isn't one for yellow?
Thanks,
Colin
Thanks,
Colin
