I have tried the "Deep Cleaning," which can be interpreted as "flooding the printer with ink to flush it." The blue just will not print. I have resorted to dropping water on the printhead absorber to dilute the collected ink ink and then siphoning it off, to no avail. Other colors ar OK, but blue is completely stopped. Is there a way to fix, or am I going to have to buy a new printer?
I should add that I have had the printer for 4 years, printed at least 15 packages of 500 count paper and many 8 1/2 X 11 photographs, and only recently had the problem with the ink. I have also used refill ink, which has worked as well as Canon. I suspect clogging of the printhead due to evaporation, but the dilution method described had no effect.
