Trigger 37
- Dec 23, 2006
Hope someone out there knows how to clear this problem.
1. I560 Priner has clogged Magenta printhead. Nozzle test shows all other colors are just fine.
2. Remove printhead, clean, soak in Windex, dry, reinstall.
Same print problem,.. not one drop of Magenta.
3. Disassemble Printhead per instruction of Niffy-Stuff forum.
Found that Magenta head totally clogged. Cleaned, rinsed, dried, and re-assembled.
4. Installed in printer with good ink carts. Printer light blinks orange 5 times (which according to Canon web site= Printhead not installed properly.)
5. REmoved and reinstalled all ink carts and printhead. cleaned contacts on printhead.
6. Green Power light will not come on. (has not come on since it gave me the 5 orange blinks. But the PC can still see the printer and I was able to command the printer to do a deap cleaning and it did it. I did a couple more deep cleanings since when I cleaned the printhead, all ink was removed.
7. Tried to print a nozzle check. Printer moved the paper and sounded like it was standard print routine. However,.. not one drop of ink on the paper.
8.. REpeat cleaning,.. check printer monitor status= Printer online, paper position OK, INK levels up in all inks, try one more nozzle test print,... printer responds with blank white page.
9. Tried to use Resume/Power function enter "Service MOde". Would not go to service mode since no Green lite under any mode. Attempt to enter service mode gave me one Blink of orange light. At least this tells me the power led is still working.
10. Pulled power plug, re-incerted, re-installed printer to PC,.. now it will not respond to any function from PC.
11. Since these printers can be serviced without a PC, how do I force it into Service MOde if there is no green light. It does power on (but no power light). The carriage will move to the center of the printer when you open the cover.
12. I have backup i560's but I'm not sure I want to install that printhead in any other printer, and since I have a backup printhead, I'm not sure I want to try it in this printer.
ANY SUGGESTIONS WILL BE APPRECIATED.
B.
B.
