dparadowski
- Apr 9, 2005
I have any interesting, to me anyways, question. I have has 3 canon printers, a i960, IP5200, and now an IP6700D. On each printer I have noticed that the Cyan ink is the first and only ink to give me problems. After refilling a few times pictures develop streaks in the beginning. After seeing this happen, I noticed it was the cyan that was missing. I Printed the detailed nozzle check via the button sequence and low and behold the cyan is missing a bunch of lines. I let the printer sit a few minutes (20-30) and try again. This time a perfect pattern. I try a few pictures, and after about 2 I get the streaks again. I print the detailed nozzle check and the cyan is missing lines again. The first time this happened (on the i960) I bought the IP5200. After a few refills the same thing happened. I decided to buy new ink from we-ink thinking it was old, about 6mos., and the problem seemed to go away. Then about a month later the same thing happened. I read the forums and decided to purge the cartridges. This seemed to work for about 2 more refills. Now I have the 6700D and I'm getting the same problem, again with only the Cyan. If I put in and OEM the problem goes away, so I know it's not the printer/printhead, and I can't believe I got 3 different printers with defective cyan nozzles.
Has anybody else had anything similar happen to them. If so how did you solve it. Any ideas would be greatly appreciated. I am leary about diluting the ink, because I don't know how far is too much and have read that it's hard to tell if the viscosity to too much or too little.
