jackson
I have noticed problems after refilling the bci-3ebk tank(s) with HC ink.The nozzle check fails miserably (the grid pattern) and repeated cleaning cycles are required to get an acceptable print (although, as a test, removing the cover on the fill hole results in the ink flowing freely from the exit hole).
Note that the tanks were tried in two printers with the same results.In each case this was the first refill for these tanks.
Two were original Canon tanks.One a third party tank (not HC).They work eventually, but the hassle/production ratio is discouraging.
I will try a virgin HC cart at the next replacement to see if they make any difference.
