Best 60" printer for Colors ? Epson vs Canon vs Hp
TR41
Narnia
Epson 1500w
Epson 11880 vs Canon IPF 9400 vs HP z6800
Or turn an epson 11880 to a Claria dye ink printer...
That’s a real loaded question, because you’re really the only one that can truly answer that correctly.
Each of these printers are much the same as each other and are very good at what they do but it all depend on what market your aiming for, I would gladly use any one of them.
Question:- Why would you want to use dye inks in the 11880 ?
Smile
Europe EU
You can turn any piezo pigment ink printer to dye because you can adjust the inks via RIP driver. The nozzles are made to eject different droplets from same nozzle so no surprises there.
With HP, Canon - thermal heads there are dedicated nozzles of certain size only. These are designed for certain ink type DYE or Pigment. While Pigment nozzles tend to be larger and will not clog. But I would recommend EPSON with proper RIP of you choice and ICC profiles, Certification to make sure your workflow is stable and performing optimal.
TR41
Narnia
Epson 1500w
"Question:- Why would you want to use dye inks in the 11880 ?"
Because it is the best visual result I can achieve
I make some kind of HD Posters. If my number one priority is "Visual strenght" over "Longevity", it is the best choice I can do.
Well that certainly answered my question, I’m just going to my room now..:eek: :D
